yamahakid1 Posted March 29, 2006 Report Posted March 29, 2006 the shifter wont shift up sometimes. you can go down to first, neutral, 2nd, 3ed, 4th but sometimes it wont get to 5th or 6th but other times it will. has this ever happened to anyone else? My banshee has some wierd shit going on since this rebuild dang. Quote
yamahakid1 Posted March 29, 2006 Author Report Posted March 29, 2006 ive ben pushing down on the shifter with my hand Quote
blueshee03 Posted March 29, 2006 Report Posted March 29, 2006 sounds like the shift shaft adjusting eccentric is out of adjustment or worn or both.could also be the shift shaft its self.if the spring on the end that hooks the pins on the shift drum is bad that will do it.might want to pull the clutch cover and check it out. Quote
Fastrat Posted March 30, 2006 Report Posted March 30, 2006 Is your motor running, or are you just playing around with it in the garage. If you rock the quad back and forth, or moving it would be better, it should shift fine. Just sitting stationary, it probably would be normal operation as you describe it. Quote
yamahakid1 Posted March 30, 2006 Author Report Posted March 30, 2006 yea your right i just need to get oil in her and get her totally running first. Quote
