cexualcensations Posted March 19, 2006 Report Posted March 19, 2006 I am building a motor which concists of ( .030 over 795 piston, 4mm long rod stroker,cool head 18cc domes,trinity pipes,dyna ignition,v3 reeds,mx port) I cant figure out which carb setup to run either the dual 35mm carbs or trinity cv 35 or38 carb. i am mostly using this bike for mx, trails and somestimes i might do alittle drag racing my friend honda 400ex. Which carbs setup do you reccommend. Quote
trex banshee Posted March 19, 2006 Report Posted March 19, 2006 you could put stock carbs on that bike and still beat the 400ex but you would be starving the motor if your going to be doing more trail then the drags you should go with the 2:1 but dual 35's will definitly get the job done! Quote
