LeadBoots Posted March 18, 2006 Report Posted March 18, 2006 ok i now have a nice white spark but its not getting gas all the time. when i poor gas into the spark plug hole it will fire rev up and then die. then it wont start again until u put more gas in. what is wrong? Quote
trex banshee Posted March 19, 2006 Report Posted March 19, 2006 it could be a couple things first i would take your fuel valve out of the tank and clean the screens then i would clean your carbs and all the jets.this is just simple stuff, but it could be more have you had it running lately like it should? or is this a bike you just got that you have never had running? Quote
LeadBoots Posted March 19, 2006 Author Report Posted March 19, 2006 no man its ran great ever since i have had it never had a problem. then i took it apart to clean and repaint everything and now i am having problems. i didnt take the engine apart at all. Quote
trex banshee Posted March 19, 2006 Report Posted March 19, 2006 well then....have you checked the screen in the tank? how about the mains and pilots in the carbs? Quote
batoutofshell Posted March 19, 2006 Report Posted March 19, 2006 did you put the choke tube between the carbs back on? if you took the carbs off and apart did you switch the fuel bowls? Quote
LeadBoots Posted March 19, 2006 Author Report Posted March 19, 2006 (edited) i really havent worked on carbs before so im not quite sure on how to do everything. i will look at the mains and pilots in the morning. yes the choke tube is hooked up and no i didnt take the carbs apart. and i didnt look at the screen but the petcock is working great. gas is getting to to carbs. Edited March 19, 2006 by LeadBoots Quote
trex banshee Posted March 19, 2006 Report Posted March 19, 2006 ah ok well then i would definitly check your jets next then. Quote
