Well I got home from work early. I am going to split the cases tonight. So far I have all the plastics off, gas tank, clutch cable off, engine mounts off, carbs off, drained coolant, just have to finish letting the oil drain out and I will pull the engine and put her up on the work bench and start tearing it down. I am taking pics all along the way and will post them up here whenever I stop tonight. I should have everthing disasembled tonight and probably drop in the 4mm stroker crank tomarrow some time and put it back together if I find nothing wrong inside.
475239[/snapback]
would really like to see a step by step process would help me out alot
475283[/snapback]
I can do that. I will have to start where I am at right here. Pulling the engine out of the frame. I will do step by step pics of engine tear-down for you.
- Jared
Thats exactly what i was doing earlier but i didnt know i needed a flywheel puller to pull the damn thing out :angry: ! Does anyone know how to take one off without a flywheel puller? thanks and good luck Red!
- Jared
475304[/snapback]
jared that would be cool , i am mecanichally inclined i know what im doing sorta . I just want to see more or less the process of getting the case split , flyweel removal and clutch removal .l... is the crank just a drop in and assemble back together or are there special tools needed , im preety sure its a drop in but forgive me if its a stupid question. just wanted to know so i can drop in 4 mil's to the two of my motors .
475347[/snapback]
It is pretty much necissary, you can get them on ebay for about $15. Its good to have since most 2 stroke bikes/quads use the same one. your only other option is to pry it off with a screw driver, if you manage to get it off you will have to spend $60 on a new flywheel becasue your old one is bent!!
475350[/snapback]
OK, i got hung up tonight because my shop light burned out and i didn't have enough light that I wanted to keep going so i stopped. I am putting together a page with LOTS of images showing what to do up to this point. I will continue with pictures and descriptions each time i work on it. As long as work doesn't kick my ass this week I should get it split by sunday or so. I will continue to post pictures as i get the pages put together. Look for a post in the mods and repairs section here in about an hour...
- Jared
oh yeah, a 4mm is just a drop in and reassemble. The pictures of when I put it back together will be really clean.
Edited by BigRed350x
- Jared
475363[/snapback]
i can not thankyou enough for showing me the ropes to the bottom end / crank side im not gunna mess with the tranny !
475371[/snapback]
Shit, I haven't even gotton into anything yet. That's all basic stuff. You have to do the clutch stuff to change a clutch so you should get good at that. Wait until the re-assembly when you have to get everything lined up right... fun fun fun. The idler gear and kick starter are fun too. It's all pretty simple once you've done a few. I've done this about 12-15 times since i got into banshee's. We even did this once in the back of a guys truck at walden when he blew a tranny. I changed out his tranny with one another guy had. Try to do it at the sand dunes and keep everything clean. lol
Hey...Jared.
I sent you a PM about the pictures and step by step...
This might be a sticky quality thread...very good info.
One tip, which...I may have skimmed over...
Once you pull the jugs, stuff a rag into the opening in the cases. You've done enough of these...I'm sure you did or almost had a circlip pop out and drop down into the cases... :o
That'll turn your mood sour in a hurry...
Great article, keep it up!!
i didnt want to clutter up your other thread, but looks like im building the same size motor as you :D
mine will be done in the next couple of weeks as well as paints and some other shinies..
