Hey everyone.
I just replaced the clutch on my friends 05 shee.
I adjusted the clutch down under the carb and the clutch lever felt firm/great.
After doing some riding today, we noticed that the clutch lever at times will go loose and not disengage the clutch. then after riding a bit, the clutch will work again. this happened a few times today.
We tried to adjust the free play at the lever and we were able to tighten it but with the adjustment screw all the way out. After some riding the clutch got loose again.
Can someone please help me fix this??
P.S. what are the tourqe numbers on the locknut at the clutch discs.
this might be stupid but what oil did you put back in????
465822[/snapback]
My friend did not know what fluids to buy since this is his first quad. So the people at our local shop told him the best stuff to use iis Motul 2-stroke transmission fluid...so thats what he brought back.
the nut probably came off the gear drive
466157[/snapback]
That would've been my next ? Did you put the lock washer back on? I never use the old one cause they always break on me ... :cry:
remove the side case cover and re check all the springs screws and adjuster nob center bolt thing , also make sure ure not runnin synthentic oil itll ruin the clutch. make sure its all cranked down to specs , i do everything to the specs
thanks for all the replies....
Im not sure if the tranny fluid we used is synthetic or not, but we definitely soaked the discs.
As for the locknut on the clutch assembly, it was definitely torqued down, everything was.
But the specs are questionable. I think the manual I read showed to torque the locknut down to somewhere between 5-7 pounds, I cant remember off the top of my head.
can someone please verify the torque specs on the the spring bolts and the locknut???
thanks again.
if everything else checks out ok and is adjusted properly, check the clutch push lever assembly. sometimes the seal will go bad and let water, dirt and junk into the lever bearing and of course it will bind up and wear out. when this happened to mine, it would bind up sometimes and be really hard to pull, sometimes it would be almost no tension, sometimes it would grab hard, sometimes slip bad, or whatever. i replaced the seal, bearing, arm, spring, etc. pretty much the whole assembly and a new cable and shee's as smooth as could be again. B)
What about the little ball bearing for the clutch lever, did you forget that?
Im not sure about a ball bearing on the clutch lever??? can you please go into a bit more detail?? Im open to all suggestions.
Thanks again everyone!!! this is a great site and shows what a forum is supposed to be like. it looks like banshee owners are pretty cool people. I am surprised at how many replies I have received for my first post. Other sites would have pointed me to the service manual, and called me a noob. thanks again.
