idle the bike and spray carb cleaner all around the intake connections and rubber parts, if the idle surges when u spray it over something you have an airleak...ir could even die when you do this...as you sit on the quad on the left side of the carbs there is a black plastic screw with a flathead on it, use a large flathead screwdriver and turn it in 1/4 turn at a time to adjust idle, if you're not sure unscrew the top of the carbs gently(no pliers..or with a rag around the teeth), pull out the sildes(note installed direction), and look 4 the screw that holds the slide up a little but..thats the idle, good luck
~Mark~
turn choke to adjust idle huh, no shit ill try that out. When choke is off, the idle is good, then it wil drop and stall if i just let it sit. It will idle high and steady, fall a bit then stall. Kinda weird, started happening when I changed the jets for the winter.
455903[/snapback]
try raising the clip to lower the needle, if this doesn't help your main my be to big.
