bansheeryder21 Posted December 10, 2005 Author Report Posted December 10, 2005 Okay let me know what you think I should do next. I got about $200 to work with here. These are my options: 1.lighten flywheel, ricky stator timing plate +4 2. 30mm oko carbs 3. Vforce reeds 4. maybe a mild port job which of those will give me more power for the money? Let me know if there is something else I am forgeting within that price range! Thanks! EVERYBODY??? Quote
odaen Posted December 10, 2005 Report Posted December 10, 2005 porting will give you the best bang for your buck. you're probably looking at $500 to $600 though when you throw in a new set of pistons and gaskets. Quote
slimeball Posted December 13, 2005 Report Posted December 13, 2005 So if you change out you carbs to 28mm or 30mm what is the hp gain right there from the stock ones? I have reeds and pipes. i am tryng todecide if I should get new carbs or rebuild mine. Quote
