I want to build a 100+hp banshee, I would like to go with a cheetah cub set up but would like to stick with a 4mill are 7mil motor. Is it even posable to get A 100+hp out of a 4mil cheetah? I will be drag racing this on AF. What is the best way to do this and what parts will I need? Thanks
  • Replies 34
  • Created
  • Last Reply
Top Posters In This Topic
Like loco said the 4 mill would be the easiest. I know a couple of guys on planetsand that are tearing the tracks up with their 4mills in stock frames. If your motor is strictly for drag racing then you might want to consider building a bigger motor. From 4 mill up the guys are all running pretty much the same size carbs and the same pipes. The only cost difference is when you get over 4 you will have to have your cases trenched. And to be safe you would probably want to go with a billet crank. From twister they are a little over a grand. I hear alot of guys talking about their 4 mill hot rods cranks breaking.
