racer Posted November 14, 2005 Report Posted November 14, 2005 Man that stock rear shocks rebound is soooo sloooooow that the back wheel prolly stay up in the air for a couple seconds after you hit a whoop 435937[/snapback] low nitrogen can also play a huge role in a shock packing................... Quote
tats4life Posted November 14, 2005 Report Posted November 14, 2005 how much preload do u have on the spring....is it single rate, dual rate?....do u know exactly how the shock was set up....and was it set up for a +4....the guy might have set it up for a longer swinger. When u make adjustments are u makin small ones or real big ones? I can dial in shocks for mx...give me some more info, hopefully i can help Quote
Polish Posted November 14, 2005 Author Report Posted November 14, 2005 how much preload do u have on the spring....is it single rate, dual rate?....do u know exactly how the shock was set up....and was it set up for a +4....the guy might have set it up for a longer swinger. When u make adjustments are u makin small ones or real big ones? I can dial in shocks for mx...give me some more info, hopefully i can help 436819[/snapback] I have a +4 swinger.........190 lbs.......and ride dunes only.....dual rate shock.......thanks for any help!! eibach spring.....w/stock shock........new realve kit hit me up Quote
tats4life Posted November 15, 2005 Report Posted November 15, 2005 whose revalve kit...where is your compression and rebound set at...what number of clicks and number of turns? is your spring set up for the revalve kit correctly...i.e. pounds per square inch, or however they figure that shit out. Quote
DUNEDEMON Posted November 16, 2005 Report Posted November 16, 2005 You say dual rate? Are they both Eibach springs? Give me the #'s off each spring and I'll tell you your initial rate and how that translates into ride quality.... Quote
RATBIKE0130 Posted November 16, 2005 Report Posted November 16, 2005 I had my rear shock rebuilt by PC out in El Cajon about two seasons ago. I had the same thing done to mine as what you did with the exception of spring rate for my weight and swingarm length. They actually got it dialed in so I didn't really need to touch any of the settings. I like a touch more compression dampening so I turned it in 2-3 clicks. Did you have the seal head replaced? Maybe they screwed something up on the install. If you need help dialing it in we are making a trip to Glamis the first weekend of December (2-4th). Quote
Polish Posted November 16, 2005 Author Report Posted November 16, 2005 I had my rear shock rebuilt by PC out in El Cajon about two seasons ago. I had the same thing done to mine as what you did with the exception of spring rate for my weight and swingarm length. They actually got it dialed in so I didn't really need to touch any of the settings. I like a touch more compression dampening so I turned it in 2-3 clicks. Did you have the seal head replaced? Maybe they screwed something up on the install. If you need help dialing it in we are making a trip to Glamis the first weekend of December (2-4th). 437802[/snapback] thanks for the info..........hey that would be awesome if i could meet you out there. I might come out for a day trip cause I work 6 days a week...........Isnt it nice to live so close to the worlds best riding place.........only 2hours away lmk Quote
MonkeyBoy Posted November 17, 2005 Report Posted November 17, 2005 (edited) You say it's too stiff. First thing I would do is to take some preload out oof the shock. Not so much that the rear drops a lot, just a little. Then take some compression out. If you camp with Bansh I can cruise out to 13.5 on TDay weekend and look at it if you want. I'll be there anyway. Edited November 17, 2005 by MonkeyBoy Quote
