  • Replies 38
  • Created
  • Last Reply
Top Posters In This Topic
68mm with stock stroke is a 392
425779[/snapback]
yes you are right. if you want to be exact :)
but when you buy trex cylinders they just say it is a 400 at 68mm, just like when yamaha says the banshee is a 350 when it is really a 347.
but yes you are right, here is a good chart link
http://www.teamracersedge.com/yamaha-banshee-products.htm
Pesonaly, I like to get all the hp/torque I can get (currently 63/35) and brag that it's stock bore and stroke. There really isn't a lot more I can do for more power though without borin, strokin or NOSin.
425828[/snapback]
Go for a drag port and alcohol. :cheers: I hope to do at least one of those mods eventually.
my setup is only a 358 and after a few breif rides(just installed) it is nothing short of astounding what a lill stock stroke can do to a mans arms when it hits the pipe !runs like a phuking scalded cat on crack :bolt: theres a repalcement for dispalcement .... and its made by cp industrys . :cheers:
426271[/snapback]
i concur...
