BANJO Posted August 28, 2005 Report Posted August 28, 2005 182 m 50 p needle clip un known.. runs great with no bog.. but it wont idle at all.. i have to lay my thumb on the gas for it to say alive.. i think my need is down to far??? i went from a 190m and a 52p... doing plug chop today. mods- fattys noss head 21cc .20 c.v 35mm no air box. tryed the idle screw it was a no go... any help please.. peace devin Quote
midnite Posted August 28, 2005 Report Posted August 28, 2005 I don't know anything about a single carb on a shee, but the needle has nothing to do with the idle. Quote
Dunsmoor86 Posted August 28, 2005 Report Posted August 28, 2005 All I can think of is make sure that pilot isn't plugged. I'm taking it idled before you put the smaller jets in? Quote
01 B4C Posted August 28, 2005 Report Posted August 28, 2005 The only jet that controls your idle is the pilot jet. Did you check if it was clogged? When was the last time the carb (s) were cleaned? Did it ever idle with the current combo? My Banshee did the same thing when I bought it. I discovered a clogged pilot jet in only one of the carbs. I cleaned both carbs and it idled fine. The needle clip and/or jet really only comes into play around half throttle. Check this site for some great info: http://www.dfn.com/benkaren/jetfaq.html Quote
BANJO Posted August 28, 2005 Author Report Posted August 28, 2005 it would not idle with the first jets.. mabe the piolit is to small??? it was a 52 so mabe ill try the 55 i got.. but no i checked it to make sure it wasnt pluged.. another question... would a dyno be good to check my jetting.. i cant really go w.o.t around here.. and i dont want to drive the shee untill i know its fine.. thanks devin Quote
Guest blew duece Posted August 28, 2005 Report Posted August 28, 2005 you might have to bite the bullit and take the slack out of your throttle cable till it idles Quote
