superman0440,
Try kicking it over 3 or 4 times with the switch off, choke pulled out. Then turn your swich on, kick it over a few times. Mines acts that way sometimes, seems to work well for me.
Need to check your compression. If it is low, your bike will start hard when cold, then start fine when everything heats up and expands. Also possible that if you have cleaned the carbs lately, you put the float bowls back on the wrong carbs. Then your choke wouldn't work properly, and might take 10-15 kicks to get it to fire.
