hey there, i was thinking of having the stock head milled for more power...
but is this a reccomended thing to do? will it add more low end or high end...
will it take away low end??
my banshee has fattys/ w/powercore 2's and K&N w/ lid off.......and jetted of coarse.......
should i consider this option?
thought anyone?
thanks
Yep...gonna do it myself. Unless you want to run race gas....or live about 2500 to 3000 ft., I'd keep it at .020 or .025.
PM Boonman, he's the man...and does a great job.
A guy I ride with MIGHT have a coolhead laying around, he said he'd GIVE to me if he found it. I offered cash, and he said I can have it. Hopefully he finds that baby!!
I would recommend it. But if I were you I would also lighten the flywheel and advance the timing +4 while you are at it. These are easy small mods that you can definately feel in the seat of your pants. Do a search. pm Boonman
The fastest bansh ive ever riddin had a milled head. God damn that sucker was fast!!!!! Though the owner was planning on buying a noss head here pretty soon.
So it all depends on how deep your pocket is. A milled head is all good, but its not adjustable at all.
Plus, those noss heads look f**kin sick!!!!!!
383794[/snapback]
Well...a milled head is 40 to 60 bucks. A NOSS head is about 240 or so.
How often do you plan on pulling your head, and how deep are your pockets.
O Rings are nice, and...if you really plan on pulling the head to "adjust the compression"...than you have your answer.
I think, however..once you get a level your comfortable with...you're going to leave it.
The NOSS head does cool a bit better, and looks trick as hell. There's no denying that.
However...if you're on a budget...get it milled. If you have the coin, get the Noss Cool Head.
