Im tryin to find a polished, preferably billet, coolant bottle like Quicksand Motorsports... If all else fails ill ahve to spend 75 bucks for a new one.. :o
Thanks,
Eric :cheers:
Don't need to fill it up. Route the hose straight down from the radiator. Any drip will go to the ground. Maybe check the Radiator level once in a awhile. I've gone out 3 trips since I 86d mine and no probs. Radiator level is still topped off. This is on 2 Summer trips too!
I kept mine and moved it behind the bumper. It doesn't spill out any more and it keeps more coolant in the radiator since the coolant will be sucked back into the radiator once the coolant cools down. And there's no sense putting coolant on the ground. You can route the hose to the front and zip tie it or make a bracket like I did for a few bucks and some aluminum angle.
Here's a pic...
