Has anyone had to change the main jet size after installing the V-Force3 reeds
I'm at 280 right now and it runs like S_ _ _ .
All I have is the T-6 pipes
It's possible. Can you elaborate on the "runs like $hit" comment? Is it flat bogging, sputtering like crazy or what? What's your elevation, airbox setup?
Scott
It idols fine, but the power band in 2nd 3rd 4th ect. gears just does not want to come on quick. It seems like it just want to gurggle. Spark plugs look dark.
I going to put new one in today after work and see what happens
378489[/snapback]
I thought you already changed your plugs? Also, you could have put this question in the post you already made about this issue rather than start a whole new thread :shootself:
sorry just trying to get some answers
Yes I did change my plugs but have not tested it yet
Wanted to get some feedback before I went home I'm still at work
If you have stock carbs make sure you put them together right after taking them off.
Slides in correct, carb tube on, no air leaks on the reed cage surface. You know, the basic stuff.
your tors might have went bad as well. Usually happens after a upgrade where you play around with the carbs or something
How do your TORS go bad after putting in new reeds?
Stumped me on that one
379335[/snapback]
By moving them around; them bumping something the wrong way....the TORS are junk!! They can easily be broken and can cause the biggest headache!!! I think the TORS removal kit is like 50 bucks....cleans up the look of the carbs and makes it easier to access them too. Also, when the TORS is removed, it's one less thing to worry about breaking on your banshee :lol:
