BrianEb Posted June 6, 2005 Report Posted June 6, 2005 I have Toomey T6 Pipes 280 Mian Jet Needle on 4th slot I just installed the new V-Force 3 Reeds and rode the Banshee yesterday. It ran like crap. The power band did not want to kick in at all. Has anyone have these problems with the V3s. I had my old spark plugs in there, Moto Tassinari says to change your plugs Could that be the problem Quote
bigboybanshee Posted June 6, 2005 Report Posted June 6, 2005 Moto Tassinari says to change your plugs 378386[/snapback] Well, did you change your plugs? And who is Moto Tassinari? Quote
ellison445 Posted June 6, 2005 Report Posted June 6, 2005 Yeap, I would throw in a new set of plugs and ride it again. Do a plug chop and check your jetting. I didnt have to rejet with my V force 2 but every bike is not the same I have Toomey T6 Pipes 280 Mian Jet Needle on 4th slotI just installed the new V-Force 3 Reeds and rode the Banshee yesterday. It ran like crap. The power band did not want to kick in at all. Has anyone have these problems with the V3s. I had my old spark plugs in there, Moto Tassinari says to change your plugs Could that be the problem 378386[/snapback] Quote
ellison445 Posted June 6, 2005 Report Posted June 6, 2005 They make the Vforce reeds Well, did you change your plugs? And who is Moto Tassinari? 378401[/snapback] Quote
BrianEb Posted June 6, 2005 Author Report Posted June 6, 2005 They are the people who make the reeds Yes I changed my plugs but I have not tested it yet because I'm at work Quote
bigboybanshee Posted June 6, 2005 Report Posted June 6, 2005 They make the Vforce reeds 378404[/snapback] Oh, OK...THANKS! Yes I changed my plugs but I have not tested it yetbecause I'm at work 378405[/snapback] Could be but the only way to find out is to ride it. If the fresh plugs don't fix it you might want to consider bumping up your timing if you haven't done it already Quote
BrianEb Posted June 6, 2005 Author Report Posted June 6, 2005 Has anyone had this same problem? Please help me Quote
wayfst Posted June 6, 2005 Report Posted June 6, 2005 i moved my clip down 2 when i changed from vf2 to vf3. thats all. if your mid range is lean your pipes won't come on very well. Quote
NEVER SATISFIED Posted June 6, 2005 Report Posted June 6, 2005 i moved my clip down 2 when i changed from vf2 to vf3. thats all. if your mid range is lean your pipes won't come on very well. 378477[/snapback] YEEEEUP lean out that needle!!!... mine is at midle clip.. i ran it at 2nd clip from stub end and plug no look no bueno.. seems ok now.. Quote
bigboybanshee Posted June 6, 2005 Report Posted June 6, 2005 YEEEEUP lean out that needle!!!... mine is at midle clip.. i ran it at 2nd clip from stub end and plug no look no bueno.. seems ok now.. 378494[/snapback] I think you mean richen up the needle If you went down on the clip position it would richen the mixture. Going up on the needle will lean it out Quote
wayfst Posted June 6, 2005 Report Posted June 6, 2005 i was on clip slot 1 to start now it's centered. Quote
chris642 Posted June 7, 2005 Report Posted June 7, 2005 your jetting must be off, sounds like everyone else said. Play with the clip a little, see where that gets you before you order new jets. Quote
NEVER SATISFIED Posted June 7, 2005 Report Posted June 7, 2005 I think you mean richen up the needle If you went down on the clip position it would richen the mixture. Going up on the needle will lean it out 378508[/snapback] dont be bustin my balls Biggie!... lol... i meant what i said ,,,go up to 2nd slot from top... atleast thas whats recomended to start at when doin these v-force thingy majiggers.... Quote
bigboybanshee Posted June 7, 2005 Report Posted June 7, 2005 dont be bustin my balls Biggie!... 378807[/snapback] LOL, sorry man Quote
redcell43 Posted June 7, 2005 Report Posted June 7, 2005 Rejet just got done with my rebuild and put VF3 back on the shee and after jeting she ran better abd stronger. Quote
