98basketbanshee Posted April 28, 2005 Report Posted April 28, 2005 I have a 98 with stock pipes kn filter hard to get started also top end not real good i have 230mains pa any ideas ? Quote
sredish Posted April 28, 2005 Report Posted April 28, 2005 I have a 98 with stock pipes kn filter hard to get started also top end not real good i have 230mains pa any ideas ? 361774[/snapback] does it help or hurt to start with choke? When you do get it started, does it idle better when the choke's pulled or does it die? Do you know what pilot is in there, stock I'm betting. You might have a compression problem as well. When have the plugs been checked last? Hard starting can be compression, reeds, jetting, plugs, electrical, so many things but answer those first few questions and we can help you more. Quote
98basketbanshee Posted April 29, 2005 Author Report Posted April 29, 2005 I have a 98 with stock pipes kn filter hard to get started also top end not real good i have 230mains pa any ideas ? 361774[/snapback] thanks im going to do a comp test also i think the pilots are stock also i found the left side carb pilot was all the way in stuck i got it freed would that effect the starting? Quote
