r6rider04 Posted April 12, 2005 Report Posted April 12, 2005 whats a good indication that a coil has gone bad? Quote
Rare Scottish Tree Badger Posted April 13, 2005 Report Posted April 13, 2005 whats a good indication that a coil has gone bad? 354138[/snapback] Bike won't run on account of no spark. . But I'm guessing that your bike isn't running and you want to find out if it's the coil. ... If you've got a multimeter, do the resistance checks or substitute it with one that you know works. Rare. Quote
gatesy Posted April 13, 2005 Report Posted April 13, 2005 I have just found that my coil went bad on me, but only one of the leads does not fire. It works fine for about 5 minutes then is starts to pop on the left hand cyclinder. So i swaped the leads over and then it started to pop on the right cyclinder. So to cut a long story short I found that if the right hand lead sparked at all it was only a weak spark. But I am only guessing that this is a coil problem, I may be wrong Quote
BenBB Posted April 13, 2005 Report Posted April 13, 2005 A high-speed miss is a symptom of a failing coil, besides the aforementioned not sparkin' or bad leads... Quote
Proquad101 Posted April 13, 2005 Report Posted April 13, 2005 A coil that is going bad will work good until it starts getting hot then it will start to break down and not work . A good indication is the bike will rev good when it's not in gear and run like crap when you are putting a load on the motor. Also have you ever changed your spark plug caps, I have had caps that made my bike run like the coil was going bad. Quote
r6rider04 Posted April 13, 2005 Author Report Posted April 13, 2005 thanks again guys i'll mess with it tomarrow luckily its still too muddy to ride anywhere here in maine Quote
