dirttrack25 Posted April 9, 2005 Report Posted April 9, 2005 As the title says just got it will be running open KnN about sea level 60-90 degrees or so has T5's and thats it.....need main pilot and needle position...thanks Quote
dirttrack25 Posted April 9, 2005 Author Report Posted April 9, 2005 So no one has any suggestions? Quote
Banshee17Racing Posted April 9, 2005 Report Posted April 9, 2005 Giver 'er time...I'm sure somebody else will chime in. Before I had put in the V-force's I was around a 170 main w/ the needle on the first or second clip from the blunt end. It's gonna be hard to try to guess where you're needle clip is suppose to be. I think that's something you'll have to mess with when you get the main and pilot set. By the way....how far away is Enfield, IL from eastern Iowa? Quote
dirttrack25 Posted April 9, 2005 Author Report Posted April 9, 2005 MapQuest says about 340...... So 165 on 3rd clip and 58 pilot should be ok for a start? Quote
brock_fuzzy_69 Posted April 10, 2005 Report Posted April 10, 2005 i am 75-80 miles or so from davenport around peoria Quote
Banshee17Racing Posted April 10, 2005 Report Posted April 10, 2005 So 165 on 3rd clip and 58 pilot should be ok for a start? 352537[/snapback] Sounds like a good start to me. Quote
theeechozen1 Posted April 11, 2005 Report Posted April 11, 2005 I would start with a 180 main and 52 pilot, needle 3rd clip mine ran like a beast with that set-up, I moved to Reno (4500' above sea-level) and it ran perfect with a 170 main and the same set-up, plug chop was dead-on **this was with a 38mm PWK though** Quote
dirttrack25 Posted April 12, 2005 Author Report Posted April 12, 2005 Any body know what size the o rings on this trinity intake are i cant find the right size anywhere? Quote
