Ok, thanks!! One more question, if I type in just Banshee Carbs, its pulling some up, but none of them are the 2 into 1s, should I just keep checking back? Or should I look under somthing else?
AND...one MORE question...If I were to find the intake manifold "plate" that leads the carbs from two to one, all I'd need then is the actual 35mm carb right??
UPDATED FOR EVERYONE ELSE!!
WANNA TRADE? I've got 2 12inch MTX Subwoofers and an MTX 331 amp, wanna trade for a Trinity Racing 2 into 1 carb set up?? This system was bought two years ago, and only used for a year (I got a new F.150-and I don't have the room for them) I've still got the original receipts and all bought them in 2003 for 600.00 (will take 400.00 now that I've had em for a year)Get them while they're still under factory warranty!!!!...LET ME KNOW if anyone is willing to trade...
no. if you go on ebay type in banshee carb. there may not be any listed right now but keep cheching and usually there will be some used ones. the ones that are upwards of 500 are from ebay stores and are barnd new
342440[/snapback]
ya keep checking back. i got mine off of there with everything except the airbox adapter and hardware but i got 2 carbs with it :D if you were just to get the 2-1 manifold you would also need the lil rubber boot to hook up to that and the carb, new slip on air fliter or air box adapter(whatever suits your riding) throttle cable, and the hardware. hope this helps and also check back every couple days on ebay and youll be sure to find a couple
