locogato11283 Posted February 28, 2005 Report Posted February 28, 2005 a while back someone posted about a website that sold all sizes and shapes of k and n filters. does anyone know what site this is?? i searched here and browsed the internet but i cant flippin find it. help a brotha out... ok i checked out k and n website and found some filters but i dont know where the hell to buy them. they have a dealer locator but is there a place that stocks all these? i need a filter with a 2.5" inside flange diameter. basically something that would fit like a 35mm pwk carb. i know someone here has prolly had one. if so where you get it? something about 4 inches across and about 6 to 8 inches long would prolly work. Quote
bansheefreak Posted February 28, 2005 Report Posted February 28, 2005 look in dirtwheels... thats where i found the website address to check out custom filters when i ordered for my old orange banshee i had.... Quote
J.J. Posted February 28, 2005 Report Posted February 28, 2005 This one? http://shop.knfilters.com/knshop/ Quote
Cotton eyed Joe Posted February 28, 2005 Report Posted February 28, 2005 This one? http://shop.knfilters.com/knshop/ 330770[/snapback] When I'm browsing K and Ns I go through that or just the www.kandn.com and click on something that shows all filters. Then you can sort between different sizes and number of openings n shit. Quote
locogato11283 Posted February 28, 2005 Author Report Posted February 28, 2005 yea i went to their website. just need to know where to buy one now. i think i can get one ordered thru advance auto parts tho.. Quote
stu Posted February 28, 2005 Report Posted February 28, 2005 when i got mine i just got the part number from www.kandn.com and took it down to my local auto parts store. they ordered it and i had it real quickly stu Quote
locogato11283 Posted February 28, 2005 Author Report Posted February 28, 2005 when i got mine i just got the part number from www.kandn.com and took it down to my local auto parts store. they ordered it and i had it real quickly stu 330898[/snapback] thats what i did today. thanks guys Quote
SDD Posted March 1, 2005 Report Posted March 1, 2005 What part number did you order? Justintoxicated, Inflames, myself, and another guy from a different board all run RU1090 filters (3.5" outer diameter 6" long 10*angle to help clear the pipes) and 115-6T outerwares. I have Alba special order them for me but they should have at least 8 in stock right now. These will fit 33-35 PWK carbs and maybe 38 PWKs as I believe they are from the same castings. Quote
locogato11283 Posted March 1, 2005 Author Report Posted March 1, 2005 What part number did you order? Justintoxicated, Inflames, myself, and another guy from a different board all run RU1090 filters (3.5" outer diameter 6" long 10*angle to help clear the pipes) and 115-6T outerwares. I have Alba special order them for me but they should have at least 8 in stock right now. These will fit 33-35 PWK carbs and maybe 38 PWKs as I believe they are from the same castings. 331421[/snapback] man thats real close to my part number. it was ru something or other. same dimensions you stated too. once i get it ill know for sure. this is going on my cr500 banshee so i dont have to worry about clearing the pipes. Quote
SDD Posted March 1, 2005 Report Posted March 1, 2005 RU-0620 2.25 in (57 mm) 3.5 in (89 mm) 6 in (152 mm) Rubber 0.625 in (16 mm) 0 degrees RB-0620 2.25 in (57 mm) 3.5 in (89 mm) 6 in (152 mm) Rubber 1 in (25 mm) 5 degrees RU-1090 2.25 in (57 mm) 3.5 in (89 mm) 6 in (152 mm) Rubber 0.75 in (19 mm) 10 degrees RU-1720 2.25 in (57 mm) 3.5 in (89 mm) 6 in (152 mm) Rubber 1 in (25 mm) 20 degrees These will fit 33-35 pwks 34pjs for sure... maybe 38 pwk and 36pj Quote
locogato11283 Posted March 1, 2005 Author Report Posted March 1, 2005 mine has a 2 7/16 inside flange diameter, and all the other measurements are the same except it has a 2 inch long flange. Quote
