I bought a 1981 XR80 from a garage sale for $20.00. Now only problem, it doesn't run. No compression. Now if I set the valves, re-ring, and hone the cylinder, will I be able to have enough compression to where the bike runs?
20 dollars? I wish I could find deals like that. XR80 is a classic. I'd love to have one for my little nephew. A piston kit for that bike is cheap. If you have a four stroke wore out to the point that it has no compression, then it either has a hole in the piston, or has a LOT of miles on it and will most likely need bored anyway. But then again what do I know.
