I have my engine apart and my flywheel and stator are very rusty. The little black pick up thing on the stator has rust and the flywheel is covered in rust. the stator plate is corroded as hell too. My bike is an 03, should I replace thees parts? Could I get by with just a new stator and plate and keep my rusty flywheel? It looks terrible, I cant believe it runs.
ps. is the ricky stator kit that cost $255 (flywheel, stator, plate) worth it?
Edited by 1800bigk
You don't need the flywheel. If you buy they're stuff, just get a stator and a plate.
The plastic cover that covers the flywheel/stator only has a generic rubber seal on it. Can I use yamabond along with that rubber thing? When I pulled the cover off there was a water pool in the bottom of the cover so I know it leaks. I try to avoid water but sometimes I cant.
312000[/snapback]
I just use a gasket sealer/maker & have never had any problems.
How about drilling a "drain hole" in the lowest point of the cover?
312021[/snapback]
I wouldn't...seems that would defeat the purpose of sealing it, a hole would let in moisture & oxygen...even if it would drain, there would still be moisture & oxygen...thus hardcore rust. :shootself:
i had the same problem with my flywheel rusting. what i did was bead blasted the flywheel at my work which cleaned it up real nice. next i sprayed a rust inhibitor on it which gave it a light waxy coating. then just sanded the pickups on it and its fine. i rode in the snow 3 or 4 times and when i took the cover off last weekend, the flywheel looks the same as the day i bead blasted it
Mine was rusted aswell!
really really really bad, couldnt believe it still ran!
Make sure the drain hole UNDER your carbs is open!
if its blocked water will not drain and a pool will form on your engine.
the water will then go trough the stator cable into your stator cover.
Thats what happend to me.
I got the ricky stuff at the time:
adjustable timing plate
200w stator
new flywheel
45W headlights (for the stock lights)
works fine.
