bansheeryder21 Posted January 21, 2005 Report Posted January 21, 2005 I was just wondering what is the best PSI to run on paddles in soft sand? The tires say 5psi but I have heard around 10-11psi. What do you think? Also the front tires too??? Quote
racer Posted January 21, 2005 Report Posted January 21, 2005 (edited) 3 - 5 all the way around Edited January 21, 2005 by therail Quote
ledofthezep Posted January 21, 2005 Report Posted January 21, 2005 Really I adjust mind according to sand conditions. The softer, the less pressure, the more packed/wet..the more pressure. Quote
super88_banshee Posted January 21, 2005 Report Posted January 21, 2005 For dry sand i usually run about 2.5-3 psi..it helps with traction a lot Quote
tschoeberl Posted January 26, 2005 Report Posted January 26, 2005 I like running 4psi in the front and 3psi in the back. Alot depends on what kind of tires. The harder the tire, the less air pressure you want to run for traction. Quote
Wallrat Posted January 27, 2005 Report Posted January 27, 2005 I usually keep mine around 4psi so that I can jump without worrying about bending anything. Quote
