while it sounds fitting...i don't think we've seen much more than a no handed landing...if that out of the ol banshee freestyler. If putting your hands behind your back before you land is considered freestyling..he's your man!
307086[/snapback]
ohh cool man but i did not footers and nohanders and those little stuff but im asking if a double can can or superman can be done on a banshee ;)
Anything can be done on anything, if its fast enough, and the banshee is fast enough, you just have to have the balls to do it.
307104[/snapback]
my friend i have balls but the banshee is heavy i mean it needs a style of a jump that can balance it in the air unlike the z400 when i jumped it it was balance and then i cam at higher speed with the banshee but i went to a wheelie in this air so i thought it may need some maybe lightweighted stuff or better shocks so i just wanted to know what do i need to do it correct on anyjump
That has to do with your skills then, a two stroke isnt going to jump like a 4 stroke. You just need to practice on a 2 stroke and you can do it just as good as on a z400, but if you want to lighten stuff, then I guess you could remove tors, parking brake, I wouldn't remove gussets because you're jumping, but you can get lighter bumpers as well, thats all I can think of for now. and suspension helps a lot...from what I've heard, some +2+1 a-arms, and some elkas wouldnt be a bad idea, also a swingarm.
Edited by iceman
307184[/snapback]
You've just got to hit it with confidence and know your machine. How much throttle you give it and where you give it off the ramp is the key to "hucking" the correct jump. Practice an you'll get it.
307260[/snapback]
hmmm.... so u say there is no need to get lighter stuff and better suspension i can do a double cancan on a shee
well i just watched huevos 6 the 4th time lol i think im ready
thanx
Iceman's got it right! Its all about skills. You should be in a position on that quad where you can be ready for anything. It only takes a second for things to go wrong(like your front end coming up on ya)I would tell you to keep your head just in front of the handlebars,arms bent elbows up. that way your ahead of the problem and not part of it!
  • 3 weeks later...
listen to these boys they know what they are talking about..but if you are planning on jumping kicker ramps or anything on your shee i'd deffinately get a swinger,get ur rear shock rebuilt by elka,get some elka front shocks,and possibly an aftermarket axle and a-arms...im building a kicker for mine right now..all i have is +2 a-arms and an axle...i dont have shocks..
