91s10 Posted January 11, 2005 Report Posted January 11, 2005 what im a new b and i got a problem wit my 97. basically it dont kick start up unless i put a little gas inbetween the spark plug and the cylnder? but im pretty sure there is fueel get threw the lines and all cause i remeber the plugs were wet. yea and after it stars to run (after 3-4 times of dippin gas in the cylinde,kickn it, then stall basically till it warms up) it will usually kick start up the day after when its compltely coold down but if it sits for about a week or two ill have to do that annoying method. this is a pain in the ass considering that things a gashog and only ride itso often but any tips woold be good thanks Quote
pimpeinkc Posted January 11, 2005 Report Posted January 11, 2005 sounds like your bowls on your carbs might be leaking down, i would take your carbs apart, check the float to make sure your bowls are filling up proper, and you can turn the screws to see if fuel comes out. and you should check and make sure your jets are not cloged. the only other thing i can think of is to check and make sure you don't have any air leaks around the reeds and carbs. good luck man. Quote
blk02banshee Posted January 11, 2005 Report Posted January 11, 2005 make sure carbs are clean, and floats are set at the right hieght. Also, make sure your carbs are adjusted correctly (syncronized and airscrews both set the same) Low compression will make it VERY hard to start, so you might want to do a compression test. Quote
bigboybanshee Posted January 11, 2005 Report Posted January 11, 2005 Low compression will make it VERY hard to start, so you might want to do a compression test. 304997[/snapback] That's what I was thinking...I'd check that first before you go to all the trouble of cleaning your carbs, etc... Quote
FIRST BANSHEE Posted January 12, 2005 Report Posted January 12, 2005 That's what I was thinking...I'd check that first before you go to all the trouble of cleaning your carbs, etc... 305000[/snapback] me too, the comp or bad reeds. Quote
H250RHATER Posted January 12, 2005 Report Posted January 12, 2005 That's what I was thinking...I'd check that first before you go to all the trouble of cleaning your carbs, etc... 305000[/snapback] but if its not that check ur floats in ur carbs my lt 500 did that before they were adjusted right Quote
91s10 Posted January 13, 2005 Author Report Posted January 13, 2005 i donno...i put new reeds in a while ago the compression is fine plugs r new from what i remeber the carbs are clean ill check out the float bowl n needle n clean em thanks for the help maybe ill get to ride her this weekend and i just gotta say BANSHEES ARE THE SHIT!!! Quote
