williamjernigan Posted December 21, 2004 Report Posted December 21, 2004 My friend has a banshee and he wants to burn alcohol. What will he need as far as motor work carbs, reeds, and domes or any information you can give. He has a stock motor. Quote
Holyman Posted December 21, 2004 Report Posted December 21, 2004 A little Tortuga rum and Pepsi was always one of my favorites Quote
banshee76179 Posted December 21, 2004 Report Posted December 21, 2004 A little Tortuga rum and Pepsi was always one of my favorites 295859[/snapback] Word Quote
racer Posted December 21, 2004 Report Posted December 21, 2004 i believe you ned new carbs and a purge system, no other motor work is necessary i dont think. check out planetsand, a ton of guys over there run it. they will get you hooked up. Quote
Bensshee Posted December 22, 2004 Report Posted December 22, 2004 You will need to get a set of carbs converted for alky, you will need around 155 to 165psi. I have never ran alky on a non ported set of jugs so I am not sure how that would work out. Also I have always used v force reeds with alky. You need to advance your timing also. I'm sure I am forgeting something but this should get you started. Quote
boonman Posted December 22, 2004 Report Posted December 22, 2004 Jason, (Screamin_banshee) used to run alky on stock porting.. Quote
Bensshee Posted December 22, 2004 Report Posted December 22, 2004 How did it work for him. Did he still advance his timing? Quote
NYUK Posted December 22, 2004 Report Posted December 22, 2004 if you are not strictly draggin, i wouldn t bother.you will use twice the fuel and premix.alcohol is more touchy with temp and humidity.factor in a top end when tuning a bike on alky. Quote
boonman Posted December 22, 2004 Report Posted December 22, 2004 It worked good for him, but he was running out of frames, and doing strictly draggin.... Quote
