Ok, I just got my banshee back after it had been apart due to a dead stator...while it was apart we put a adjustable timing plate and stator from ricky stator in it...The motor internally is stock..it does have 35 mm keihins and T-5 pipes on it...I live and ride at 7000+ feet..what kinda advance or retardation should i put on this thing?
Edited by CowboyBanshee
Yep, and you line the mark with the split in the case (where the case halves meet)
294382[/snapback]
Luckily I have a pic from when I was installing my RS stator on the adjustable plate...timing is not set here but should explain fixitrod's statement. :cheers:
I run mine a "box hair" over +4. :shrugani:;)
