I believe they changed pattern in 95, so I don't think they're the same bolt pattern. If it was a 95, they'd be the same, but someone can confirm that.
Will the banshee 94 rear hubs work w/ the 02 Banshee rear hubs?
I know some have smaller and bigger patterns so is the 94 the bigger one ?
287661[/snapback]
87-89 are different, 90 on up should be the same.
If your asking if you can take the hub off the 94 axle and put it on the 02, you can.
I just need to make sure the 94 pattern on the rear hubs are the same as my 02 thats all...
So i can put the hubs from the 94 on my 02 and my rims still bolt up .
