Meat Posted November 29, 2004 Report Posted November 29, 2004 These are mine, free shipping to BHQ members. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMESE%3AIT Quote
NugShee Posted November 29, 2004 Report Posted November 29, 2004 Hey, I always wondered how well those spacers work. Did you like them when you used them? Are they funny looking on the shee? Did you notice a diference in handling? good or bad? Please let me know as I might get a set but dont want to if its a bad idea. Thanks in advance, Mike Quote
Meat Posted November 29, 2004 Author Report Posted November 29, 2004 They bolt right up to your rear hubs and then your rims bolt to the spacers. They widen the rear of your quad 4 inches and it simulates a 4 inch wider axle. You can't see em when they're mounted unless you look on the inner side of your rear rims. It will make the quad more stable, slides the ass end easier, makes the quad feel more secure at high speeds. Some say they will put too much stress on the axle, but I used em for 2 years and never bent my axle. I used a set on my Quadracer and never bent that axle either. Now if your a racer... you should look into a wider\stronger aftermarket axle, but if your a recreational rider, a dune rider or just do small jumps you should have no problems with axle bending with these installed. Keep in mind, I am a small guy\150lbs. You'll def notice the handling difference, no doubt. Quote
ikikazz Posted December 3, 2004 Report Posted December 3, 2004 everyone can use 4" more i only got 3" to the ground Quote
Meat Posted December 5, 2004 Author Report Posted December 5, 2004 WHEEL SPACER AUCTION IS ALMOST OVER SO I THOUGHT ID BUMP THE THREAD AND SHOW YAS SOME PICTURES..... http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMESE%3AIT Quote
