Bansheeman1121 Posted November 27, 2004 Report Posted November 27, 2004 Here we go, took the banshee out for a quick spin so on the way it runsdecent but on the sh#ty side of the fence. It was like the throttle was sticken open, becuasewhen you wouldletof the gas it would still pull a bit. Soi get back to my house and felt the need to ride a bit more so i takeit in a field part of my yard and slam bam thank you mam 1st gear sticks open and somehow my slicks hook up on the grass and the front end goes skyward and i fall off and the quads ridin on the grab bar then finaly flips and snaps the part that connects the tie rod to the tire, the little ball joint deal.. How much do those ball joint things run?? And somethin seems to be sqeakin in my front tire now when i roll it 9in nuetral Quote
nater006 Posted November 27, 2004 Report Posted November 27, 2004 You can't replace the factory balljoints, as they're welded in.. gotta get a set of arms. You can probably find a used set of stockers, or aftermarket ones on Fleabay, or some new QSM ones or similar will be great. Quote
superchicken Posted November 28, 2004 Report Posted November 28, 2004 it sounds like he broke a tie rod end not a ball joint.but i think he needs to chime back in cause reeding that post gave me a head ache. oh,i got a few tie rods with ends if ya need one. the squeeking may be the cotter pin rubbing the inside of the rim,it happened to me bfore but ya never know after a crack up like that Quote
FIRST BANSHEE Posted November 28, 2004 Report Posted November 28, 2004 sounds like you need a tierod end, youmight find one cheap on e-bay the sqeeking cuold be wheel bearings. Quote
PUSH THE THROTTLE Posted November 28, 2004 Report Posted November 28, 2004 You can get the Tusk tie rod ends for about $20-25 per rod(both ends) @ Rocky Mountain. I had to buy them when I went to my quicksand arms and haven't had a bit of problems with them. Quote
