Ok I just rebuilt the top end on this shee. Put it all back together
and it starts fine every time. When warmed up, in neutral from idle
to WOT sounds great, no problems at all. Put it in gear and 1st and
second gear fine third gear all the way through 6th and it sputters
bad. Just wont run right at all. What I think may be the problem is I have
a tiny leak in the head gasket, cause after running through the gears till
I reached top speed, I let off the gas, and saw a little white smoke or steam, not
sure which, come out of the pipes. What would be the easiest way to check for
a hesd gasket leak and what are the tail tail signs of this problem.
Have not run it much maybe a total of 30 minutes since the rebuild
would I see any signs on the plugs, cause they look ok to me, tan to
brownish and fairly dry. Any help would be great.
Could be a number of things air leak,carbs, or ignition..
U can try the carb cleaner trick for a air leak..spray it where U think it's leaking from..
If the plugs looks ok than rule out jetting...
Did U have the flywheel off for any reason or messed with the pick-up coil..
If so, it should be gapped between 18 to 25 thous. and check the gapped on the plugs also... :confused:
Edited by banshee76179
is it sputtering or back firing, sounds like it got hot. check your coolant level, if it's backfiring its probably lean. if it's laying down and sputering it's probably fat. double check everything, make sure you have good gas, and try it again. but don't run it out if it's not right, look for the problem
Welcome
Edited by FIRST BANSHEE
Thanks for all the help, I did a search and read and read. Today I started it up
to see if their was any sign of residue or bubbles in the antifreeze. I also was
looking to see if it would just plane poor out all over the place. Nothing
no sign of anything, not even movement in the fluid. It stays cold as the
head heats up to where I can't touch it. So I took the pump cover off
to see whats up. Should this spin when you kick it over cause it doesn't
I can free spin it, with no resistance at all. So now my question is how do
you replace this and would this cause it to sputter.
285625[/snapback]
you need to replace your impeller your overheating, yes that will cause it to sputter, don't ride it untill its fixed. get a manual the repair is easy. good luck
:bolt:
