I am going to install my new -1 chrome lonestar swinger in the next few weeks or so. But I was thinking that since I will have all that stuff off the bike I might as well have the rear shock revalved at a shop. Should I do this? I know Ive read that it can make a big difference. I weigh about 160-170 so should I go ahead and get it for about 175pounds in case I gain weight. How should the bike feel after this is done. I mostly ride trails but if I find something I can jump I will.
If you got the money, like you said...since it's apart, you may as well. you won't regret it, it'll ride better & handle more to your liking. But if you just trail ride & don't jump a whole hell of a lot & go big all the time, then you'd probably be alright. I assume this is a stock shock we're talking about? :unsure:
I'd put the swingarm on first. It will stiffen it up and you may be happy with it. It only takes a few minutes to pull the shock off if you want to rebuild it later. I had mine rebuilt while putting a -2 swingarm on and it came out to stiff. Try it first and see what you think.
