Anyone have any good info for me? What i need to know is how to move my needle. I need to move it up a notch to lean my shee out in the middle. Problem is, i'm not sure what i need to do to get it out and move it up. Anyone with some pics or just some good info??
Pull the cap off, slide the spring up, slide the cable out of the notch, remove the two screws holding in the brass retainer, pull the needle out, move the clip up. Reverse to put it back together. 5 minutes for each side max.
one more question...if i moved the needle up(clip down) am i leaning out the middle or richening.
richening
Just think about how the needle is shaped and where the fuel is coming from. If you raise it, the skinnier part will open the hole (venturi) sooner.
