I have a 1998 Banshee. It has fatty pipes with pc2 silencers. K&N filter with no lid. TORS removed. The jetting is 290 mains, needle on 4th clip, 27.5 pilot and 1.5 turns on the airscrew. I am having a problem when she is warm. It will run great up until it starts to get warm the it will start to sputter alot on the low-end. I thought it was rich on the pilot but, when I went to a 25 pilot it will backfire and pop alot on the low-end, went to a 30 pilot and noticed no difference. I was just wondering why it would only do this when the bike gets hot. Is there possibly something I am overlooking or is it a possible electrical problem. I have checked for air leaks with carb cleaner and nothing was found. I am completely confused. Someone please help!
I had a similar problem, except it sputtered on low end all the time. I got fed up and bought new PWK 30mm, jetted at the factory for my shee. Still sputtered on bottom. I adjusted the air screw leaner and put my needle at the leanest position It had previously been at the next to leanest pos. It screamed after that.
When I still had stock carbs, I also put the stock pilot back in (going down from the #30 I had in it). It didn't work.
You'll get much better advice than this, but just my 0.02. :)
When it suptters does it smoke? And what do the plugs look like after it has idled for a bit, do they have quite a bit of oil on them?
What happens when you put the choke on?
It doesn't sound lean, because if it was it would rev up and just be a plain bitch.
Have you taken your carbs apart and cleaned them? Usually when I have a problem with my bike and I know it's fuel related, I always clean my carbs and see if that fixes it (and it usually does)
It sounds to me like youre running a little rich, but you seem sure you're not.
Do you have a clymer manual or did you read the bhq jetting faq? Theres more info there that might help.
Hey I had what seems to be the same problem. I gave up and took it in to a shop, and it took them a while to get it dialed in. Here is what they ended up doing:
310 main jets
30 pilot jets
Try it before you knock it. Also make sure the carbs are perfectly syncronized.
Hope it works, mine is bad ass now
if it is falling on it's face when it gets hot, there can only be a few things wrong with it. make sure your fuel lines are not up on any thing to create vapor lock, go and buy a new spark plug boot and switch it out between the two, or if your rich buy two and change them both, about 3 bucks each, lol. as it heats up things expand so check your head torqe and also your carb mounting. make sure every thing is tight. and when you say hot i assume you mean after it is warmed up i start thrashing on it, which means check your reeds, your air filter and your floats/fuel lines. if you can give a description as to, i changed this and i got this problem or it ran fine and out of no where it started fu@king up, that would help figure out the prob. the 2 stroke is the most basic of engines and if the prob came out of no where or it came up after changing some thing is a really big difference. hope to hear from you.
