nickxc Posted August 8, 2004 Report Posted August 8, 2004 How do I know what size domes I should get for my shee. I am thinking of getting a cool head but how do I know what size doms I should get. I wanna run pump gas like I am now. my mods are in my sig?? any help appreciated!! Thanks!! Quote
frocashmoney24 Posted August 8, 2004 Report Posted August 8, 2004 id say stick with some 21cc's you should be safe, get a NOSS head , they kick major ass Quote
Banshee~ Posted August 8, 2004 Report Posted August 8, 2004 id say stick with some 21cc's you should be safe, get a NOSS head , they kick major ass yea noss has some nice stuff "dlnoss" will probley find this post and tell you..I would say 21's if your at sealevel Quote
nickxc Posted August 8, 2004 Author Report Posted August 8, 2004 ok im looking at a used cool head and It has some 22cc domes so that would be cool to start with then right?? also is there any place I can buy the longer studs other than right from prodesign?? Quote
dlnoss Posted August 8, 2004 Report Posted August 8, 2004 If you buy a new Pro Design head it should come with studs. If you buy a Noss head you don't need them. 22cc would be safe but not give you as much of a performance boost as you could get with 21cc. You should be okay with 21cc and your mods if you run premium pump. How much is your compression with the shaved head? Quote
nickxc Posted August 8, 2004 Author Report Posted August 8, 2004 How much is your compression with the shaved head I think it was like 126 last time I checked ( about 2 or 3 weeks ago) This head is used and the kid said he doesn't have the studs they where on the cylinders when he sold them i guess. Quote
dlnoss Posted August 8, 2004 Report Posted August 8, 2004 I've been hearing of people paying $40 for a set of studs. (I should make some and sell them) Depending on how much your head is shaved, 22cc may not give you much more compression since stock heads are usually around 23cc. Have you already bought the head? Do orings come with it? I'm asking because if you have to buy domes, orings, and studs after buying the head it may be less expensive to buy a new one with 21cc domes. Quote
frocashmoney24 Posted August 8, 2004 Report Posted August 8, 2004 not to mention acorn nuts and washers that cost like 18 bucks from prodesign i think Quote
nickxc Posted August 8, 2004 Author Report Posted August 8, 2004 I decided not to buy it for now. it was gunna end up being $125 for the head with 22 cc domes then shipping then studs from prodesign are $34 and he said one of the orings was missing so I would have to come up with one of them too. I am just looking for an aftermarket head cause I keep blowing head gaskets. Im on my third one this summer and at $20 each I would be farther ahead to have an aftermarket head. Quote
Banshee~ Posted August 8, 2004 Report Posted August 8, 2004 I decided not to buy it for now. it was gunna end up being $125 for the head with 22 cc domes then shipping then studs from prodesign are $34 and he said one of the orings was missing so I would have to come up with one of them too. I am just looking for an aftermarket head cause I keep blowing head gaskets. Im on my third one this summer and at $20 each I would be farther ahead to have an aftermarket head. my friend has a prodesign and we had to pull his head and replace the head gasket at LS Quote
nickxc Posted August 9, 2004 Author Report Posted August 9, 2004 my friend has a prodesign and we had to pull his head and replace the head gasket at LS wow, I thought that those O rings lasted a long time... that was my main reason for getting an aftermarket head. Quote
dlnoss Posted August 9, 2004 Report Posted August 9, 2004 The orings do usually last a long time unless they are damaged during installation or there is some other problem. Quote
nickxc Posted August 9, 2004 Author Report Posted August 9, 2004 I really like the looks of the nos head and Ive heard alot of good stuff about them. If I had the cash to just go buy one that would be the one I'd get. unfortunately I cant blow $200 right now but I'll prolly be able to get one soon ... Quote
