ok, i think i may have fingured out why this damn thing isn't starting. i took out the spark plugs and hooked up the wires and kicked it and i didn't see a spark. i even turned the lights off in the garage to see if i could see it and still nothing. when i got the banshee it had a single pipe on it and now i have dual fmf fattys on it and the headlights switch is relocated to the left frame like barely touching the left header pipe. could the pipe have caused it to head up and burn a wire or some crap like that? i don't know what to do and i am about to roll this thing off a cliff because ever since i got it it's been poopy. lol. hope you guys can help
just unplug your kill/headlight switch and try kicking it again with the plug grounded. if it still doesn't work unplug your key switch and put a jumper in the plug to make sure it's not your key switch.
ok i found the problem. i unplugged the switch like tats said and it sparked. i put everything back together and it fired right up. now how would i go about getting the switch working again? would i need a new switch or what? is their anyway i could wire it up so i could just use the kill switch and do away with the switch completely? thanks guys. i don't know what the hell i would do without you guys
  • 4 weeks later...
