papa_smurf49319 Posted May 23, 2004 Report Posted May 23, 2004 (edited) I have to buy a head now and i saw a Pro Design one for 200$ without domes, and i see a noss head is 195$ without domes. Whats your opinion on which one i should get, i just need a new head because mine has some dings in it from the blowup. Pro Design http://www.magicracing.com/myProducts.cfm?...&CategoryID=120 Noss Head http://www.nossmachine.com/banshee_heads.htm My Stock Head http://bikepics.com/pictures/153533/ Edited May 23, 2004 by papa_smurf49319 Quote
Screamin_Banshee Posted May 23, 2004 Report Posted May 23, 2004 BUY NOSS!!! You cant go wrong man, not only does David give a discount to HQ members, his customer service is TOP NOTCH. Also u wont have to change ur studs, as the "new" style Noss heads use stockers. The domes are interchangable between the two brands u mentioned. Quote
papa_smurf49319 Posted May 23, 2004 Author Report Posted May 23, 2004 ya i will probably go with the noss head. Quote
SICK BOY Posted May 23, 2004 Report Posted May 23, 2004 (edited) If you ever have a problem with the Noss head you can talk directly with Dave and he'll take care of it.If you have a problem with the Pro Design you can call them,be put on hold,talk to a guy that dosen't give 2 shits about you,be transfered to a even bigger asshole,and waste a whole day and still have the same problem.The choice is yours. Edited May 23, 2004 by SICK BOY Quote
dlnoss Posted May 23, 2004 Report Posted May 23, 2004 I have to buy a head now and i saw a Pro Design one for 200$ without domes, and i see a noss head is 195$ without domes. BHQ members get a 10% discount. Also,,,Screamin_Banshee has a used one for sale. Quote
papa_smurf49319 Posted May 23, 2004 Author Report Posted May 23, 2004 dlnoss could i still use my stock head or is it in two bad of shape Quote
Holyman Posted May 23, 2004 Report Posted May 23, 2004 Dude you have the POS head now you need the NOSs head You can always get another stok head if the money is too tight for an aftermarket head. Quote
Yaxy Posted May 23, 2004 Report Posted May 23, 2004 I have no experience with Noss products in general but I have with Pro-design. For starters my shee has almost every part that prodesign assigns there name to and through my dealing with them the last 7 years they are very customer service oriented and are more than willing to go out of there way to help with any calls that I sent there way. They have quality parts and back up the parts they sell. As far as the heads you do have to replace your head studs which can be a pain, but I have no isseus with mine. But the 10% discount sounds nice Chris Quote
dlnoss Posted May 23, 2004 Report Posted May 23, 2004 dlnoss could i still use my stock head or is it in two bad of shape It's pretty bad. I wouldn't use it. Like Holyman said, you can get a used stock head pretty cheap if you don't want to spend the money an aftermarket head. Quote
Bansheeman1121 Posted May 23, 2004 Report Posted May 23, 2004 How are the power gains from the noss head and does it give the same running temp advantage as a cool head?? Thanx for any help.. Quote
dlnoss Posted May 23, 2004 Report Posted May 23, 2004 How are the power gains from the noss head and does it give the same running temp advantage as a cool head?? The power gains vary with dome size and other mods. In my experience, I have never had a customer tell me they were dissatisfied with the performance gains, or anything else, with the head. As a standalone mod, you can usually expect a 2-5 hp gain and better throttle response. The first heads I manufactured cooled about the same as the PD head. With the current design, flow characteristics were improved which provided better and very even cooling. Quote
