Hadnt started the shee in quite a while and pulled it out and tried to start it and it wouldnt start.....wouldnt pop start.....nothing.
So I pulled the carbs, cleaned them and threw on my v-force reedcages (you need to cut the stock intakes to put them on right?).
Ended up my needles were gummed up a little bit, threw it all back together and got it to fire up but it was only running on one cylinder.....If I rev'd it up it would kick the second cylinder in, but it was idling real high when it was only running on one cylinder.
Pulled the sparkplugs.....was checking them for spark....trying to find everything that was wrong....and nothing.....
Then I look back on my rear tire and saw the choke tube......I was like bangheadbangheadbanghead
Put it back on and it runs great now. Those v-force give me some great low end pull as its coming up to the powerband. I notice my off idle....like if I'm just off and on the gas in first gear its really bucky. Not smooth like it was with my dual stage boyeson's. Any ideas on how to get rid of that buckiness?
