Do any of you have a basically stock Banshee with 21cc domes? Thinking about doing this to mine, but would like to hear some opinions pro and con. Thanks
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
You probably want the opinions of other, unbiased people but......
You will realize a 'feelable' boost in overall power most noticeable in the lower RPM range. The head and pipes are two of the better 'bolt-on' performance mods. A clamp-on filter is also a must on the Banshee to replace the crummy stock setup.
-David
I installed it on my friends and it is easy to do. IT looks awsome and preforms well. I honestly cant think of a single con but money. But compared to other heads it's probably the cheapest. I'll be getting one soon
I put a 21cc noss head on my 04 shee and It hauls a-- now.... Great bottom too. Get one from David (noss) he is great to deal with....
Edited by Banshee33
They said it..
Yes u will notice a difference in the performance with the head. It will also help cool a little better, and looks ALOT better than stock.
If and when u decide to install an aftermarket head, I suggest the Noss heads over the rest, for a few reasons. Quality is awesome, fit is great, easy to install, and the customer support u get from David is awesome! When u are ready, PM him (dlnoss) he offers a 10% discount to HQ members, which is always nice!
Edited by Screamin_Banshee
I looked at the noss site and it says compression would be 146 with 21cc and 171 with 20cc. I'm at 2372ft. if 91 oct is the highest I can get what is the best dome without detenation. I'm building a trail monster and want lower end pull.
Thanx,
Jeremy :cheers:
That chart is a little on the high side. At your elevation and with your mods, you could run 20cc domes with 91 octane. If you took a trip to somewhere below about 1500' I'd bump the octane up for the trip.
I just recently got one of those "OTHER" brand heads with 17cc domes which I know are way too small for me. I ride 600 to 800 feet trails. Stock bore. Hey Dave... what should I get and your domes fit the "Other" guys right?
They will fit the PD and, with an additional notch, a Vitos. 21cc would be safe, 20cc would be pushing it with pump gas. Any other mods?
Hehe.. was going to ask the same :) 600 ft above seal level, with the "other" brand (came w/ the quad). running 93 also... T5s, K&N, 30mm carbs, and its ported. Currently running 138lbs in each side on 22cc domes.
I don't know that I would raise the compression any more with the +4 timing on 93 octane.
