yea so i took off the top end today to notice a hole in one of my pistons and the guys on here said that it's cause by a lean mixture. the jets in my carb are a 172 and a 48. i'm not sure what clip the needle is on. should i change them? i am around 1000 above sea level and i'm running 15cc domes. i run straight cam 2 race gas. i have a fresh top end that's bored .060 over. i was also wondering if it would be ok to use the same domes from the old top end. i was also wondering if i should change the reeds out too.
My vote goes to detonation.
Even with the race gas, 15cc domes are pretty tight.
60 over - maybe the domes would have to be re-cut to match the larger bore and correct the squish band some...
Any idea what the compression was after the rebuilt and what the squish was set at?
