I bought a set of pro series reeds and the package only came with 2 pedals do I need to buy more or is it one pedal for each reed and you leave one side of the reed stock and the other with the pro series on it??? also do you need to put the cages back on the cover the reeds?
You need 2 packages of reeds for a total of 4 petals. Make damn sure they rest flush against the cage. If they don't, flip them over. Also, don't overtighten the screws. This will warp the petals and they will not sit flush. Instead of cranking on the screws, use blue loctite and just snug them down. Check them after a couple of hours riding.
