wodeman Posted April 19, 2004 Report Posted April 19, 2004 After some hard racing and powershifting, my banshee only has 1st and 2nd gears, wont click up any more. It seems that I can only find neutral with the engine off. Any ideas before I tear it apart? Thanks Quote
ledofthezep Posted April 19, 2004 Report Posted April 19, 2004 Welcome to the HQ. in a nut shell...(Do a search & you'll find several posts like this) Take your clutch cover off, move your shifter & you'll see that the piece on the end of the shift shaft is bound up on the shift star, allowing you to only move it up or down one gear....you'll see what I mean. Just take a small flathead & un-bind it. Then put it back together & pull your shifter off, place a rubber washer on that shaft followed by a couple regular washers and bolt the shifter back up. The rubber washer will keep the regular washers from grinding into the stator cover. This will eliminate the left-to-right play of the shift shaft that allows it to bind up. Ride on! Quote
