ledofthezep Posted April 1, 2004 Report Posted April 1, 2004 Just curious...don't believe you have to, but do you have to crack the case to replace the shift shaft? Mine keeps getting bound up on the shiftstar, pops out & I have to un-bind it. Shimming up the shifter has helped, but I believe the piece on the shaft that shifts the gears along the shift star is bent a bit *I think*& since shee's naked to the frame right now & I have the motor on my work bench I thought about replacing it. Was just wondering for sure or not if you have to crack the case to get'r dun? Quote
pimp559 Posted April 1, 2004 Report Posted April 1, 2004 No, you can pull the shift shaft through clutch side easily after removing the shifter. Check to make sure the lock nut and tab are tight on the pivot pin. Mine came loose before and caused shifting problems. If you pull the shaft make sure you get a new seal on the shifter side. Quote
vmaxup Posted April 1, 2004 Report Posted April 1, 2004 I broke that pivot adjustment once in half. Then it came loose once. You have to have it adjusted correct. This pin is bent from the factory so you can adjust its like a little cam. I thought it was my shift shaft. Thought it was bent. I was stuck in 5th and 6th those little fingers that grab the posts on the shift star were out of adjustment.turn it while in any gear and it should si equal distance between the pins on the shift star. I reread your post and ill bet your just out of adjustment. locktight and a 12 mm will hold it with that bent tab washer. But back to the question just take off your clutch cover and remove your shifter. Then just pull it out. I do remember. And im shure it was you. You told me to put some rubber washers on the out side of the electrical cover between the shift lever. This gets ride of the slop of the shift shaft moving in in out. It works Great Quote
ledofthezep Posted April 2, 2004 Author Report Posted April 2, 2004 Thanks a lot guys, helps a lot. Give's me some things to check. I do remember. And im shure it was you. You told me to put some rubber washers on the out side of the electrical cover between the shift lever. This gets ride of the slop of the shift shaft moving in in out. It works Great Yepper, that was me. Was just thinking of trying a sure-fire cure...if there's such a thing. Thanks again. Quote
boonman Posted April 2, 2004 Report Posted April 2, 2004 I will have the sure fire cure soon boyz and girls. How does a thrust bearing and shaft collar sound? TO go up against the CASE, not the flexible side cover...... Positive placement of the shift shaft..... And unnoticeable to the untrained eye..... Quote
badass_r6 Posted April 3, 2004 Report Posted April 3, 2004 sounds great boonman. always thinkin, aren't ya? Quote
boonman Posted April 3, 2004 Report Posted April 3, 2004 I do think alot. Too much. It gets me in trouble. I'm thinkin next week. SHould have everything set up.... Got to find the cheapest supplier..... Quote
rebelbanshee2 Posted April 4, 2004 Report Posted April 4, 2004 I will have the sure fire cure soon boyz and girls. How does a thrust bearing and shaft collar sound? TO go up against the CASE, not the flexible side cover...... Positive placement of the shift shaft..... And unnoticeable to the untrained eye..... i have the same setup on my bike works very nicely Quote
vmaxup Posted April 4, 2004 Report Posted April 4, 2004 Rebeshee Give us some pics or show us your set up. I want to do it Quote
ledofthezep Posted April 5, 2004 Author Report Posted April 5, 2004 Rebeshee Give us some pics or show us your set up. I want to do it Yeah, get us some pics! ...curious to see what ya come up with boon! Quote
Ducman Posted April 5, 2004 Report Posted April 5, 2004 What size (mm) is the shift shaft anyway? I need to get a washer with the correct inside diameter to try Leds little shift shaft play eliminator trick. Quote
ledofthezep Posted April 7, 2004 Author Report Posted April 7, 2004 Couldn't tell ya ducman,...I just got me a rubber washer off of some sink hose, and a handful of washers I had laying around & found a couple to fit snug on the shaft. Boonman,...where ya at? Quote
