XTShee Posted March 30, 2004 Report Posted March 30, 2004 I have been meaning to ask about this for a while but keep forgeting about it. Its probably a simple fix, but I thought I would ask before I spent hours screwing around with my a-arms and getting nowhere I installed new +2+1 a-arms awhile back and I have found that when I turn hard lock to either the left or right the inside wheel of the direction I am turning will lock in place and I cannot bring it back by turning the bars. Whats happening is the tie rod is getting on the wrong side of itself if that makes any sence. I found that the tab on the frame at the bottom of the steering stem was bent a bit foward so I bashed it back and it fixed the problem a bit, but it can still happen. any ideas on what to do? I am also using +1 offset front rims if that would make any diffrence Quote
erbilabuc Posted March 30, 2004 Report Posted March 30, 2004 only true way to fix it is to gusset the tab. All banshees are succeptible to this problem Quote
XTShee Posted March 30, 2004 Author Report Posted March 30, 2004 Thought that might be the case, thanks for the reply, I guess I will do some welding tonight. Quote
BenBB Posted March 30, 2004 Report Posted March 30, 2004 Erbilabuc is right on, mine did the same and I had to reinforce it. Just be careful not to make it any wider than stock; not sure what's worse, having the wheels lock and you can't move 'em back or not being able to correct enough in a fast powerslide... Quote
