I have a 96 banshee with pipes and k&n I am thinking about ordering one of the noss machineheads and im not sure what size domes I should get for it. isnt the more compression the better? I was thinking with going for some 19cc domes is that to much compression? I do have my crank welded so it should be able to handle it.
The dome size depends on several things: Elevation, other mods, fuel to be used, porting, what kind of riding you will be doing, and a few other things. Since your crank is welded, that won't be a limitation.
What kind of fuel do you plan on running? 91 octane pump gas, or mixed 1/2 with race fuel, or straight race fuel? If your at sea level you'll need at least 1/2 mixed or possibly straight race fuel with 19cc domes.
