rock Posted March 15, 2004 Report Posted March 15, 2004 just wondering if anybody has run into this the o ring on the adapter where it meets the airbox loses it's seal. seen this happen a couple of times to check remove air filter shine flashlight into hole look for light between adapter and airbox Quote
ranshee Posted March 16, 2004 Report Posted March 16, 2004 When you fist buy the thing you should use some silicone all the way around the flange. Put that sucker on and never have to remove it. as soon as you do you are going to rip that stock foam gasket. You should only have to remove the filter to check inside. Quote
