Banshee33 Posted March 2, 2004 Report Posted March 2, 2004 Hi Guys, I want to put a noss head on my new banshee can you tell me what CC I will need? I'm at 200 Ft above sea level? I want to run only Premuim gas. Thanks to all that can help. Quote
Blue Duece Posted March 2, 2004 Report Posted March 2, 2004 i was safe with 20's on stock juggs in death valley at 500 feet below sea level and im in cali we only get 91 octane...21's would be good and safe anywhere Quote
Banshee33 Posted March 2, 2004 Author Report Posted March 2, 2004 Great thanks . I have 93 octane here Quote
Blue Duece Posted March 2, 2004 Report Posted March 2, 2004 great glad to help..and i think you'll find david at noss a great guy to buy banshee goodies from......if you have any problem he will jump through hoops to see your taken care of......follow the torque pattern on your stock head and use some good clean grease on the orings when you install them, go around your head ten times if need be with a smaller ratchet that doesnt have a lot of leverage and just snug it up before just torqueing each nut to 20 pounds, and that head will never leak, he machines them real nice...... Quote
Banshee33 Posted March 2, 2004 Author Report Posted March 2, 2004 Just ordered them up. Went with 21cc to be safe. Quote
getonit Posted March 2, 2004 Report Posted March 2, 2004 i ran 21s for a year on 93 pump gas and never had a problem Quote
SICK BOY Posted March 2, 2004 Report Posted March 2, 2004 If you have any more ?'s with your head just ask David Noss.He's a great guy and will go out of his way to help you out. Quote
Banshee33 Posted March 2, 2004 Author Report Posted March 2, 2004 I talked to dave he said 21cc to be safe. I ordered it already . Will I see a difference in power? Quote
SICK BOY Posted March 4, 2004 Report Posted March 4, 2004 Put it on and take it for a ride,and you can answer that one. Quote
Ducman Posted March 4, 2004 Report Posted March 4, 2004 I talked to dave he said 21cc to be safe. I ordered it already . Will I see a difference in power? Mainly torque on the lower to mid rpm range. It made my technical hill climbs much easier because a lot of times when I would have had to feather the clutch and spin the wheels before now I can just use the throttle, not spin the wheels, and accelerate untill I hit the band. It makes it feel smoother going into the band because it pulls harder down low before the band kicks in. Theres probably more power all around but it is hard to tell because the power is smoother from the torque. A lot of difference in cooling though, makes it alot harder to overheat. Quote
