check the seal in the water pump. just check your oil. if its way high and milky green thats what it is. take the clutch cover off and the water pump impeller out and replace the seal in the waterpump.
what kinda head are u running??? if its pushing fluid out the over flow like u say the head gasket might not be blowed but it could be leaking. check to see if u have back pressure on the radiator cap let it run for a few min then twist the cap and see if it has pressure but be careful when doin that lol.. if it does then u most like have a head leaking somewhere u may just have to re torque the head and this will clear it up
it could abe normal if u just did a rebuild, after a rebuild take off the radiator cap and let it run for awhile, it'll kick all the air bubbles out and suck the coolent from the resivore like crazy, fill it again and see if it keeps doing it, if it dont it could be that
