I have a set of 19cc domes and I'm building a short rod stroker motor. There is a machine shop next to my work and the guy will cut my domes for free. Problem is, that I don't know if there is anything special about cuting .80 off of them. If anyone could tell or show me in a picture how to cut them I would appreciate it.
I HAVE SOME DOMES, THEY CAME OUT OF MY +4MM STROKER. THEY HAD 180LBS COMPRESSION IN MY BIKE WHEN I TOOK THEM OUT, THESE ARE FOR NO SPACER PLATE. +4MM WITH NO PLATE, LET ME KNOW IF YOUR INTERESTED.
It's pretty difficult to make stroker domes out of pre-existing domes. If the squish band is cut out 2mm you will turn a 19cc dome in to something like a 13cc stroker dome. If the chamber is reworked to maintain the volume, the spark plug would be sticking down into the chamber unless you made it a flat-top chamber like an alky dome. Patriot racing makes stroker domes if you decide to buy some.
David, do you cut alky domes also? I am going to be needing a set soon.
Dan at Patriot would be better for the alky domes. I have made some to other people's specs but am no expert on them.
Mooney, caps lock button.  It is located right next to the "a" key, and directly under the "tab" key.  You need to locate this.  And use it.  ;)
yeah sorry i am at work and we have to type everything in caps here i forget what i am doing until its too late.
